Hanging Toilet problem..Flex when used
Discussion in 'Toilet Forum discussions' started by Dan Linzy, Sep 4, 2004.
  1. Dan Linzy
    Dan Linzy New Member
    Sep 4, 2004
    Have Case Wall Hung toilet..that squeaks and flexes when you sit on it. Movement appears to be slight but squeak sound is audiable.
    Is there a way to shim the mounting to eliminate the flexing and sound.
    Apprecaite any guidence
  2. jadnashua
    Is this a new installation? Or an old one that started to have this problem?
    If new, the wall may not be flat, and shims probably would help. If the wall is flat, either new or old, and the toilet moves, either the bolts are loose, or the blocking that holds it up is too weak or decayed (maybe a leak internal to the wall?).
    Ideas from a non-pro...
Similar Threads: Hanging Toilet
Toilet Forum discussions Case 3000 Hanging Toilet Aug 17, 2015
Toilet Forum discussions Purchased Toto Guinevere toilet. Changing out handle? Jan 18, 2010
Toilet Forum discussions Changing out a 1955 Toilet Oct 1, 2008
Toilet Forum discussions Changing to a flush valve toilet Apr 27, 2007
Toilet Forum discussions Anyone have a Toto THU223#CP part hanging around? Oct 18, 2016
