Gurgling sound under kitchen sink
Mchiarit
South Carolina
There is a gurgling sound under my kitchen sink after water goes down the drain. It does not happen all the time and when it does occur, it usually does so after about five minutes. Even though I have never smelled sewer gas, I replaced the AAV anyway thinking it may be defective, but that did not solve the problem.
This first began about eight months ago when I had a reverse osmosis filtration system installed under my sink. At the time, it was explained to me that after dispensing filtered water, the system generates waste water while the RO tank is being replenished. However, careful observation indicates the sound of the waste water is different than the gurgling sound. Furthermore, the gurgling sound occasionally occurs even after the regular faucet is used and many hours after the latest filtered water has been dispensed.
Could there be a connection to this sound and the RO system even when the filtered water is not being dispensed? The dealer who installed it insists not.
Dj2
California
You might have a partial blockage.
Have the drain line cleaned by a machine, not a chemical.
WorthFlorida
Solutions
Orlando, Florida
There is a partial block and wastewater is laying in the pipe, the block releases then the remaining water drains rapidly. Similar to when a full sink drains and at the very end you'll hear the water sound like it is sucking air. Nothing to do with the RO system.
