First, some photos for reference:
https://imgur.com/a/EStMYRg
https://imgur.com/a/Jn5JwId
Top is old (disconnected) pump. Bottom-right is new (installed) pump. Bottom left is original (installed) pump for other zone (functional).
I have a forced hot water heating system with baseboard radiators. Five individual zones are fed by Grundfos Alpha 15-55f pumps. One basement zone, three 1st floor zones, one 2nd floor zone. Near the end of last winter, one of the first floor zones stopped circulating, and pump showed only the double dash, which manual says means either voltage, air, or stuck rotor (?):
- I bled the zone by opening the return and making sure pump was powered. Water flows out the return with no noticeable bubbles.
- With multimeter, confirmed zone is getting +120V, same as the other (functional) zones.
- Power cycled, pump boots up and starts running at low (1 watt), but goes back to double-dash within ~10s.
- I purchased a nearly identical pump (only difference is front says PC1442 instead of PC1449, couldn't find what that means). When installed, it showed the same double dash.
- I got some suggestions on reddit. 1) Swapped in the electrical connection from one of the working pumps - no effect. Still double dashed line and no circulation. 2) Hooked up garden hose to return spigot, disconnected pipe above pump and pushed hose water backwards through zone. Filled HD bucket 5x (first three times water was dirty), closed without letting air in and reconnected, but no effect - still double dashed lines
- One curious thing - when touching some of the pipes/nuts/Feed-Pressure Regulator, I at times felt the tingle of electricity. Nothing painful but pretty sure I wasn't imagining it.
