Great Basic Shower head help needed please
Discussion in 'Shower & Bathtub Forum & Blog' started by chrissy, Dec 17, 2005.
  1. chrissy
    chrissy New Member
    Sep 12, 2005
    I need help on finding a great shower head. Not a hand held or multiple shower heads type one. Just a basic one that connects to the basic type plumbing that comes out of the wall. One that is simple to install. Like unscrew the old one and screw on the new one-LOL My DH likes it to have multiple settings. he likes the one that is really strong for rinsing.
    I am plumbing challenged-LOL
    I have been going through the Home Depot ones. Have not found one yet.
    Any suggestions????
    Thanks so much!!!! :)
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Try the other big box store.
  4. jadnashua
    I'm partial to Grohe, but I've not really tried that many. I bought my mother one, and she really likes it. Assuming you have a standard shower arm, it truely is unscrew the old one, put on some teflon tape, and then screw the new one on. Most of them are that way. If you have an odd-ball shower arm, it could be more complicated. The one I bought her has four settings. The nozzles are a semi-rigid plastic materia. If they get limed up, you just brush it with your fingers, it flexes slightly and it all comes off.
  5. jimbo
    jimbo Plumber
    If you are hoping for a really strong spray with lots of water, it is not going to happen. It is against the law. You have to get used to the taking a low flow shower. I have found the Delta/Alsons to my liking.
    You could check your household pressure and insure if is above 60. I keep mine up about 70, and that does help the shower.
    I am not crazy about any of the fancy massage functions, and find they do not work well unless you have very good pressure.
  6. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    shower
    The cheap ones are good enough to take a real good shower with.
    You get all wet just as with all shower heads.
    Some of them are even better and last longer.
  7. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Drill Out the Flow Restrictor
    "If you are hoping for a really strong spray with lots of water, it is not going to happen. It is against the law. You have to get used to the taking a low flow shower."
    It's against the law to sell them but the water police aren't going to arrest you if you fix your own shower.
    There is usually a restrictor with a small hole that is visible and accessible if you disassemble the things that will unscrew. Taking some care so you don't wreck something or hurt yourself, drill out the restrictor to as large as you can, and try to chamfer or round off the edge of the inlet side of the hole. A Dremel tool often works great.
    Even a 50% increase in diameter adds a lot to the flow capacity of a restrictor.
  8. Lumber Jack
    Lumber Jack New Member
    Jan 4, 2006
    I'm a big fan of the military style shower head, they're about $2 at most hardware stores and they are small metal piviotable heads. They preform great, with great pressure and they're really easy to install. So simple, so perfect.
Similar Threads: Great Basic
Shower & Bathtub Forum & Blog Greater then 5 gpm. cycle stop valve Jan 17, 2014
Shower & Bathtub Forum & Blog Great Stuff under tub? Feb 5, 2008
Shower & Bathtub Forum & Blog Sterling Ensemble, Basic questions Oct 22, 2016
Shower & Bathtub Forum & Blog Recommended basic tub/shower faucets? Dec 20, 2014
Shower & Bathtub Forum & Blog A very basic question about shower heads Nov 29, 2012
