Gravity fed sprinkler system
Discussion in 'Irrigation / Sprinkler Forum' started by schoony04, May 5, 2013.
  1. schoony04
    schoony04 New Member
    May 5, 2013
    CA
    I'm looking to do a sprinkler system on our property (part of the property). We are in a high fire zone so we're looking for a perimeter around our house with an in ground pop up system. Why not above ground? We have 3 large dogs that have proved in the past they will break off stationary above ground sprinkler heads/lines.
    We have recently purchased a 500 gal. water tank which the sprinkler system will be hooked up to (tank will also be a back up in case our well goes under) we're planning on mounting the tank on top of the ridge along the backside of our property (approximately 20-30 ft higher than where the sprinkler system will be installed)
    I'm planning on running approximately 20-30 heads on 3-4 timed systems. (run at 3-4 separate times)
    Total length of the full system will be approximately (high estimate) 700 feet of 3/4" pvc.
    My question is will the pressure of the gravity be enough to run these sprinklers or would i need a small pump to force the pressure through the system? The sprinklers will be the only thing on the system. All of our house water requirements are hooked up to our well. If a pump is required should I look at a 1/4hp, 1/2hp, 1hp, 10hp, etc etc etc. Any recommendations on brand, model, etc?
    Sorry for the rookie question, never taken on a project quite like this before - always been on city water where pressure was never an issue. Thanks in advance
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Well.. you get about .43 PSI per foot of elevation so raising the tank about 100 feet should do it.
  4. schoony04
    May 5, 2013
    CA
    Sarcasm noted.
    So I need a pump, any recommendations on type, size, gph?
Similar Threads: Gravity sprinkler
Irrigation / Sprinkler Forum Sprinklers for Gravity Fed System Jul 24, 2008
Irrigation / Sprinkler Forum Gravity Irrigation from large tank at 100 feet Apr 9, 2014
Irrigation / Sprinkler Forum gravity feed calculation help !!! Jun 3, 2010
Irrigation / Sprinkler Forum help with sizing a gravity feed tank pipe Mar 26, 2009
Irrigation / Sprinkler Forum How to know which zone on valve goes to which sprinklers Feb 19, 2017
