Ok so I have a 75ft bored well with a Gould V60 pump. Recently my water has been running out after only a short period of usage. So here is what we've noticed.
First: My air pressure gauge is broken
I am making a trip tomorrow to replace it.
Second: My power bill has jumped about $100.
Third: The switch is shutting off after about 3 minutes of continuous use (this began today) however I have never had a problem with my water pressure.
I have been reading through the forums and I believe my problem is due to short cycling. I wanted to add that when the pump shuts off I lose water completely.
Here is where I am confused.
I'm not sure if it's a pressure sensor switch malfunction or the air pressure of the tank.
When the tank is full we get a psi of 20 and from what I have read that is to low.
Sorry for the long post but I am trying to give as much info as possible to get the best advice.
I guess I am asking is 1. What is the psi supposed to be on a full bladder pump and 2. What is the best way of checking?
I can't give you the switch on and switch off setting until we replace the pressure gauge.
Any help would be appreciated because I would like to check the simple things before I pay someone to come check it out for me.
Thanks
Thanks
