Good softener air gap?
SteveW
DIY Senior Member
Omaha, NE
I am looking for a decent pre-made air gap for a Kenmore softener. I have done a search but not finding much, and few if any reviews of the ones I have found online. Some of the reviews were negative, mostly saying that either the unit may not have a built-in way to attach the plastic drain hose, or for those that do, the barbed fitting on the air gap has a small enough diameter to slow the flow.
Any leads you can offer on a decent air gap setup for connecting a plastic drain hose into 1 1/2 in. PVC standpipe?
Bannerman
Ontario, Canada
Depending on the softener's drain flow rate, that may not be an actual issue but a simple solution would be to increase the drain line diameter and air gap fitting size. For instance, if the softener has a 1/2" diameter drain fitting, adapt up to a 3/4" drain tube directly after the softener and install an air gap with a 3/4" fitting.
https://www.plumbingsupply.com/airgap.html#softener
http://www.airgap.com/mr_drain.html
Cacher_Chick
Test, Don't Guess!
I have never used a prefab air gap. A pair of pipe standoffs to secure the hose above the receptor works fine.
Where the adjacent wall is finished, I make a splash shield by cutting a stub of PVC pipe lengthwise and zip-tie it across the back of the air gap. The same thing can be accomplished by notching the top of the standpipe.
SteveW
DIY Senior Member
Omaha, NE
Thanks! Will give one of these a try. Probably go with the first one as it seems to be ready to go. The 2nd one needs a fitting to adapt to the hose and not really clear from their website how to order those.
ditttohead
Water systems designer, R&D
Ontario California
We sell a ton of mr. drains and I have personally installed hundreds of them.
Don't be surprised if a little splashing occurs. I don't recommend installing them in areas that are easily damaged by a few drops of water. Outside or in a garage where a drop or two occasionally... these are great.
SteveW
DIY Senior Member
Omaha, NE
Good to know -- mine is in an unfinished basement so a small amt of water would be OK.
ditttohead
Ontario California
We are literally talking a few drops per regeneration but if it is right above a nice wood floor... not good.
SteveW
DIY Senior Member
Omaha, NE
Your last sentence sounds like something I had considered -- just putting some longitudinal slits in the standpipe below the level of the end of the tubing that I would insert into the standpipe.
