getting sand in filter
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by djarp, Jul 18, 2006.
  1. djarp
    djarp New Member
    Jun 6, 2006
    I have a 30 ft shallow well no foot valve or screen at bottom there is check valve prior to pump, everything runs great but I have a cartridge filter in line prior to the water softner. The cartridge filter keeps getting clogged with slime or fine sand stopping all flow. I have a spin down separator or sand filter prior to the pump head but it still does not help. I was told that the filter was too small for the house and to go deeper in the well min 50feet to get cleaner water ????? Can u give me some advice :confused:
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    You have a well with no foot valve and no screen, so the suction pipe is down in a casing. How big is the casing? Is it a pipe a couple of inches in diameter, or is it a large tile maybe 2 ft in diameter?
    Or is your well just a pipe stuck down in the earth?
    Draw a picture of it. The suction pipe is down there and over time sand has been getting into the casing. The well has probably filled up to the point where the sand is at the bottom of the suction pipe. Now you are getting sand into the suction pipe.
    You need to get some kind of pump to clean the sand out of the well casing, down several feet below the suction pipe. Then put the suction pipe down the well with a screen, several feet above sand remaining in the well.
  4. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Who installed this pipe in the ground?
    bob...
    1 person likes this.
  5. djarp
    djarp New Member
    Jun 6, 2006
    the well is 4 weeks old the casing is 2" gal new and the 1 1/4 pvc inside casing. The 1 1/4 pvc is 2 feet from bottom.
    When they drilled the well they used a large pump to pump the well.
    :eek:
    Im in Florida lots of sand
  6. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Refer to my last post.
    bob...
Similar Threads: getting sand
Pumps and Tanks Well Forum & Blog. Water is life. Sand repeatedly getting into well Aug 16, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Am I getting ripped off on a submersible pump? Jan 25, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Old style well not pressurizing, trouble getting water Jan 3, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Getting precharged tank pressure exact Jun 13, 2016
Pumps and Tanks Well Forum & Blog. Water is life. How is so much air getting into our water system? Mar 27, 2016
