sombrerocat
Forgot to ask -- what the heck do we do now to fix this problem? The drain pipe is cast iron.
Ugh -- it all started out with re-doing the flooring in our bathroom. We changed out our sink -- no problem. Got to the toilet -- MAJOR SNAFU. We pulled our toilet up -- and found a waxy seal mess, bent to "compensate" for the fact that the toilet and drain pipe don't line up. The toilet has a reverse trap, and is held down to the floor by 4 screws. Some of the tile behind the toilet was removed to cram it up against the wall.
The drain pipe -- I could find no discernible flange -- and could see the edge of the cast iron pipe. The hardwood floor around the toilet is -- you guessed it -- rotten. I'm dreading finding out what's beneath -- the subfloor consists of 1x6 planks placed diagonally across the joists.
The original idea was to pull up the hardwood flooring, lay down 1/2" thick plywood, 1/4" backerboard, and then the tile. But now we're stuck with the drain pipe in the wrong position for the toilet -- and need to resolve this issue before moving forward. I measured the wall to center of drain pipe which is about 9-1/2".
Fortunately we have a half bath in addition to this main bath we were renovating the floor.
