General bidet question
Discussion in 'Toilet Forum discussions' started by bobcilla, Feb 23, 2008.
  1. bobcilla
    bobcilla New Member
    Feb 23, 2008
    Hi. I would like to ask if anyone has any suggestions for the "poor man's" bidet seat. We have a well and water pressure issues and would like to start small to see how things would work. I'd like to try something for $200 or less, but even in this category is a plethra of brands: BidetUSA, bidematic, Hyundai, GoBidet, Biobidet, etc., etc., etc. I'm open to either just the cold or the warm water too. Does anyone have any suggestions??:
  2. Bill Arden
    Bill Arden Computer Programmer
    Sep 30, 2006
    computer programmer
    MN, USA
    I've looked at lot of options and have found the least expensive is to have the bathroom sink within reach of the toilet. Just wet toilet paper and use.
    The non-heated units aren't worth the money. They are either too cold, or you have to let them run too long to get the right temp.
    I hate to say it, but cold water does NOT feel good.
    The water pressure changes is not a problem.
    The best compromise seems to get a ~$300 seat with a small heated tank and add a tempering valve (if needed) so that you send warm water to the unit to prevent it getting cold during use.
    Edit: This works best if you are willing to put a hot circulating loop in.
    If you do go with a non-heated unit, remember that you will need a tempering valve that can keep the water close to the 98F desired temperature.
    Then keep in mind that you will have to dump enough water to get warm water to the head before use.
    Edit again:
    http://terrylove.biz/12-bidet
    Scroll to bottom: Heated toilet seat by Takagi, elongated
    I can't see any specs as to how much water it holds or much of anything else.
Similar Threads: General bidet
Toilet Forum discussions General Question on Toilet Finish Quality Oct 30, 2015
Toilet Forum discussions question about Toto Soiree and toilets in general May 11, 2010
Toilet Forum discussions Replacing the lower seat on a Bio-Bidet Jan 14, 2017
Toilet Forum discussions Capping Toilet/Bidet Beneath Floor Level Sep 9, 2016
Toilet Forum discussions Toto vs. Bio Bidet Washlet/Bidet Seat Aug 9, 2016
