GE water heater controller voltage
Discussion in 'Water Heater Forum, Tanks' started by KeithR, Sep 14, 2013.
  1. KeithR
    KeithR New Member
    Sep 14, 2013
    Ontario
    I have a 40 gal GE "Profile" "Smart" water heater, about 5 to 7 years old.
    Trying to trouble shoot shortage of HW,and discover voltage to the top element is 240v, but the bottom element is only getting 120V.
    Do I need to replace the top controller which feeds to the bottom one or is it meant to do this?
  2. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    What is your Model Number ?
    Good Luck.
  4. KeithR
    KeithR New Member
    Sep 14, 2013
    Ontario
    Its a PE40T9CB00
    Actually closer to 10 years old.
  5. KeithR
    KeithR New Member
    Sep 14, 2013
    Ontario
    I think I need to study it a bit closer before jumping to conclusions. My first observation was with wires disconnected from both elements. I drained and re-fillled the tank.
    Now with the top element connected, there is zero voltage at the bottom element. Does the controller cycle back and forth so only one element is on at a time?
  6. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Normally, Yes it does work that way.
    Did you have power off when you drained it ?
  7. KeithR
    KeithR New Member
    Sep 14, 2013
    Ontario
    OH yes!
    I just checked resistance. Top is 20K ohms & bottom is 7K ohms. (They are supposed to be the same!)
    Both are infinity to ground.
  8. KeithR
    KeithR New Member
    Sep 14, 2013
    Ontario
    So two new elements and we have hot again! Thanks for comments Rocket Scientist
  9. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Good Deal.
    Enjoy.
  10. hj
    An element will ONLY register 120 v. when it is burned out. It also does not heat when that happens so only the upper element operates to heat the water at the top of the tank, giving you a short supply.
  11. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Sounds like both elements were Open. If the posted readings are correct.
    That is a bit strange, unless power was applied with no water in the tank. Or one element has been bad for awhile.
  12. kahnman
    kahnman New Member
    Sep 29, 2013
    Ontario
    Hi Keith. I am having the same problem with my exact same model water heater. I did a search of the model on the GE support and parts site and no results. Do you still have the element part numbers and where you ordered them from? Thanks.
Similar Threads: water heater
Water Heater Forum, Tanks Water heater has no drain pan, what precautions should I take? Mar 6, 2017
Water Heater Forum, Tanks Hot Water Heater Flame Temperature Mar 4, 2017
Water Heater Forum, Tanks Whirlpool 10 year old Water Heater Mar 4, 2017
Water Heater Forum, Tanks Gas Water Heater Explosion? Mar 4, 2017
Water Heater Forum, Tanks Water heater not always firing Mar 4, 2017
