gas regulator vent placement
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by capt_bill, May 31, 2006.
  1. capt_bill
    capt_bill New Member
    May 31, 2006
    Hi Guys, I'm building a 3 season room here in NJ and I have a question regarding the vented gas regulator on my water heater gas line. There is a small (3/16")copper vent line that runs from the reg housing through the garage wall to the outside rear wall. This wall will eventually be an interior wall once the room construction is complete. I know I have to move this vent, I'm wondering if there is a limit distance-wise that I need to be concerned about. Can I just run this line further away and then through the wall? We're talking about 12-15 feet away from the regulator.
    Thanks,
    Bill
  2. hj
    vent
    As long as it terminates outside the building, you can run it as far as necessary.
  4. capt_bill
    May 31, 2006
    I expect I'll only need to make certain of a good tight connection when I replace the compression fitting and have no kinks in the tubing. I had an insect problem a while back and found that vent blocked ( I found out because the water heater stopped warming water). I was able to create a screened cover for the end of the line with no further difficulties.
    Thank you very much, I was hoping it wouldn't be an obstacle to the new construction.
    Bill
Similar Threads: regulator vent
Plumbing Forum, Professional & DIY Advice Correct gas regulator size and specs Yesterday at 3:51 AM
Plumbing Forum, Professional & DIY Advice How to adjust regulator Dec 24, 2016
Plumbing Forum, Professional & DIY Advice Water shut-off before and after regulator Dec 21, 2016
Plumbing Forum, Professional & DIY Advice Is rebuilding a Pressure Regulator worth it? Nov 15, 2016
Plumbing Forum, Professional & DIY Advice Adjuster Home Water Pressure - No Regulator Valve In House Dec 5, 2015
