++ Garage Heater ++
Discussion in 'HVAC Heating & Cooling' started by jrprusak, Dec 18, 2008.
  1. jrprusak
    jrprusak New Member
    Oct 22, 2008
    Anchorage, Alaska
    What's a good NG vented heater for small 450SF garage?? Mr. Heat, Lennox?? Ceiling mounted...thanks.....jp
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Reznor or Modine are 2 brands that I would consider to be good.
  4. MaintenanceMan
    MaintenanceMan In the Trades
    Dec 10, 2008
    Maintenance
    Indiana
    Modine makes a Hot Dawg series that's just for that sort of thing. They can be mounted close to the ceiling and vented horizontally if needed. There are plenty of other alternatives too.
  5. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Whatever you can afford?
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I've used a 45,000 BTU Reznor in my garage/shop for over 20 years. I leave the pilot light on year round with the thermostat set down to 55. In the winter if I want to work in the shop, I can raise the temperature to 70* in just a few minutes. The room is 24x28x12. There are no windows, two walk-in doors, 2 10x9 garage doors. The walls have 2x6 studs and are sheet rocked over fiberglass batt insulation. The ceiling is blown with 12" of fiberglass insulation. It is not perfectly air tight around the garage doors, but heat loss is not too bad. I can not compare this heater with any other, but it has worked well for me.
  7. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    I like the hot dog
Similar Threads: Garage Heater
HVAC Heating & Cooling Converting Garage to living space and water heater/furnace venting req Oct 29, 2013
HVAC Heating & Cooling Garage Heater - Natural Gas - Just installed and flames are tiny Feb 16, 2013
HVAC Heating & Cooling garage heater Feb 23, 2009
HVAC Heating & Cooling garage heater temp problems Jan 24, 2008
HVAC Heating & Cooling Garage Heater Vent? Oct 24, 2007
