Forever Storage tank.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by canton, Nov 30, 2006.
  1. canton
    canton Plumber
    Jul 24, 2005
    Massachusetts
    I had to move a 75 gallon h.w storage tank that was under some stairs so the Carpenter could work on the stairs. I moved it out of the way temporarily and moved it back. After I moved it back and bled out the zone everthing seemed fine but i noticed a small leak coming from the bottom of the tank where the supply from the zone entered. I took off the little panel and the insulation was saturated, the coil cover was rusted and all 8 nuts were corroded, the drip was coming from the gasket between the cover of the coil and the tank. I brought this to the attention of the homeowner and told her that the coil cover needed to be replaced along with the gasket and nuts and that the corrosion around the tank might cause it to let go at some time.
    She told me that the tank was 10 years old and that the company that installed it said it would last FOREVER! Well I told her that nothing last forever and that this tank certainly wouldn't and suggested that she call the installing company and have them replace this forever storage tank. She called them and they told her that the tanks probably on the way out and they'll send someone out...................Forever Ha!
    Actually after the storage tank reached full temp the gasket expanded and the leak stopped.
  2. Cass
    Cass Plumber
    Nov 12, 2005
    I doubt the gasget expanded. The tank did.
Similar Threads: Forever Storage
Plumbing Forum, Professional & DIY Advice Water takes forever to heat up and it's close to the water heater Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Have to turn sink faucet handles forever before water Jul 28, 2010
Plumbing Forum, Professional & DIY Advice Setting up 250gal water storage tank Apr 22, 2016
Plumbing Forum, Professional & DIY Advice Mixing well water storage tanks Jul 23, 2015
Plumbing Forum, Professional & DIY Advice Sediment in hot water on tankless system, from failing storage tank? need advice & referral in 98004 Apr 10, 2015
