We need some serious help! 2 year old home with 2 year old washer. At the end of the washer cycle, about 2 minutes from the end when it's spinning, foam starts to come up where the discharge hose runs into the wall. The foam is spilling over the edge of the plastic wall insert and onto the floor.
Initially, what started all this was that we were sitting downstairs and heard drip drip. There was water leaking from the ceiling. Went upstairs and water and foam all over. This has obviously been going on for quite some time as the vinyl flooring under the washer is split. The plumbing company came out and discovered the box was about 18 inches too low, cut out the drywall and moved that up. Now, the water is not spilling over, but the foam still is. Talked to washing machine repairman and he suggested using vinegar to try to clean out but that didn't work either. Any other suggestions? Maybe the venting is either clogged or not installed properly?
Any help would be greatly appreciated!!
