Flushing tankless water heater w/ vinegar
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by H20Man, Jan 14, 2008.
  1. H20Man
    H20Man New Member
    Jan 10, 2008
    Alabama
    Where do you get a 5 gal bucket of vinegar? Sams club or something?
    What about a good inexpensive pump to use for the flush? Do you just rig out some vinyl hose or whatever to the pump? I don't guess anybody sells a ready-to-go setup do they?
  2. TMB9862
    TMB9862 New Member
    Nov 12, 2006
    Five 1 gallon containers at the food store plus an empty five gallon bucket. Or a membership to a restaurant supply center.
  4. H20Man
    H20Man New Member
    Jan 10, 2008
    Alabama
    What about the pump and hoses? Just rig something up from parts from Lowe's/HomerDepot? Most pumps you see there are like effluent pumps and are quite expensive....
    Any suggestions?
  5. Gary Slusser
    Retired
    If you have hardness scale in a water heater, you need a water softener. It will prevent more build up of scale and dissolve the scale build up in the tank.
    That's much better than attempting to use vinegar and then when done ot have more scale form because of hard water, and have to dod the vinegar thing every so often.
    I suggest a correctly sized softener for the family size, water quality and the SFR required by the house. It should have a Clack WS-1 control valve.
  6. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    The small rubber-impeller "drill pumps" will circulate the vinegar. There is no significant pressure loss at the flows you will be using. They usually have threaded connections for standard hoses and washing machine hoses will work.
  7. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
  8. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    a rash of flushing questions....
    this is the second or third person
    to inquire on how to de-lime their tankless
    water heaters....over the past month....
    the last guy with a totally clogged up heat exchanger never has posted wether he was
    successful or not in freeing up his exchanger.
    maked me wonder if he ever did succeed
    I wonder if this is going to be a bigger problem for
    people with hard water than they realize.....
  9. H20Man
    H20Man New Member
    Jan 10, 2008
    Alabama
    There's nothing wrong with mine. I'm just doing it for preventative reasons like the manual suggests.
Similar Threads: Flushing tankless
Plumbing Forum, Professional & DIY Advice Gurgling in drains after flushing Jan 30, 2017
Plumbing Forum, Professional & DIY Advice Back flushing water lines in a home filled with dirt, silt and gravel Oct 5, 2016
Plumbing Forum, Professional & DIY Advice Toilet not properly flushing.. May 23, 2016
Plumbing Forum, Professional & DIY Advice Flushing Toilet, Coming Through Shower Drain... Only When A Lot Of Water Is Used Apr 25, 2016
Plumbing Forum, Professional & DIY Advice Toilet still "ghost flushing" after replacement Jan 14, 2016
