fluctuating hot water
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tds, May 14, 2006.
  1. tds
    tds New Member
    May 14, 2006
    I have an older oil fired furnace that has a small (5gal?) boiler that heats a coil for forced hot air and also one for my hot water. There is a hand operated valve to set the mix of cold water with the hot water for the shower/sink hot water pipe. It isn't thermostatic and the hot water fluctuates in temp as the boiler cools and heats between it's presets (not sure of the settings maybe 120-140F). Also noticably colder in the winter than summer.
    Any recommendations on a thermostatically controlled mixing setup that will maintain an even temp? Hoping there's a simple non-powered (metal thermostat?) type system available.
    Thanks in advance.
    tds
  2. tds
    tds New Member
    May 14, 2006
Similar Threads: fluctuating water
Plumbing Forum, Professional & DIY Advice Fluctuating water heater flame Dec 1, 2013
Plumbing Forum, Professional & DIY Advice Water hammer combined with fluctuating pressure Feb 20, 2013
Plumbing Forum, Professional & DIY Advice What's in a glass of water? Saturday at 10:38 AM
Plumbing Forum, Professional & DIY Advice Hot Water Recirc. w/ dedicated return Thursday at 10:27 AM
Plumbing Forum, Professional & DIY Advice Oil burner hot water coil Wednesday at 12:12 PM
