I am starting a basement remodel project this fall and want to understand my options and the best approaches to dealing with moisture in a damp basement. I have regraded around trouble spots in my foundation, and my basement can now survive a heavy rain without incurring any standing water. The foundation does not seem to wick much moisture, as I have tested by taping foil to the block wall and removed it after a couple days and found no condensation.
My bigger concern is the floor. The previous home owner painted the floor, and when it rains heavily outside, the paint bubbles in some spots. Again, no standing water, but obvious moisture penetration through the floor. I don't think this is extreme, but I want to understand my options for flooring. I don't think it would even be noticeable if it wasn't for the paint on the floor.
I am consider a couple of options:
Choice #1. Pergo. My thought here would be to put 6 mil poly down, topped with the foam underlayment for the Pergo, then the Pergo itself. I am assuming that mold will form under the plastic. Is that a problem for anyone other than the guy who has to replace that floor someday?
Choice #2. Carpeting. On one hand, I am squeamish about this because of the moisture, but on the other hand, if I use mold resistant pad, will this allow the floor to breath better and actually be the best option for the moisture coming up through the concrete? Am I hosed if I do get a small amount of standing water, or can I just wet vac and dehumidify the heck out of the room and not have a mold problem ultimately?
Choice #3. ceramic tile, in case there ever is a small amount of standing water, I am assuming that this is a relatively painless cleanup experience with no damage to the structural integrity of the tile.
Which one of these would you do? Is there a better option? Is there a better approach to one of these options?
Thanks for your help.
Cheers,
Paul
Cheers,
Paul
