flexible pipe under subfloor
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pronouncedeyen, Oct 2, 2009.
  1. pronouncedeyen
    pronouncedeyen Member
    Sep 10, 2009
    Baltimore, MD
    I have a 1/2" flexible copper pipe (type L) coming out of a chunk of concrete and the top of that pipe is about 1/16" above where a plywood subfloor will be laid and meet the concrete.
    Is it OK if the floor rests on the pipe? Or will it cause problems to have half of the pipe embedded in concrete and the other half weighted down by concrete/backerboard/tile because of the difference in expansion between wood and concrete?
  2. hj
    copper
    The copper should NOT be "weighted down" by ANYTHING. There should be a space between it and the wood, AND the concrete. The different expansion rates may cause problems but it will not be with the copper tubing.
  4. pronouncedeyen
    Sep 10, 2009
    Baltimore, MD
    hj: the pipes (supply & drain) were buried in 4" of concrete when the previous owners did the bathroom in the 1950s. I guess I'll try to bend the pipe down so it doesn't hit the subfloor.
  5. jimbo
    jimbo Plumber
    Copper should never be in direct contact with concrete'
  6. pronouncedeyen
    Sep 10, 2009
    Baltimore, MD
    jimbo: really? Gheez. The people who did this bathroom back in the 1950s buried copper pipes, both supply and drain, in 4" of concrete! Not only that they buried a ton of knob and tube wiring in it as well.
  7. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    If that is not a joke about the knob and tube you have a major safety problem if that is still active!! :eek:
  8. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    There are frequent posts regarding leaks in slabs where copper water lines have been buried in concrete. The problem is concrete attacks the copper. It is stupid to encase copper in concrete, but it has been common practice in slab built homes for years.
  9. pronouncedeyen
    Sep 10, 2009
    Baltimore, MD
    shacko: Are you saying the existence of knob and tube is a safety hazard or that it was buried in concrete?
  10. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    K&T is supposed to be open air, so it can keep cool... bury it, it can heat up & start a fire. Often a concern when retrofitting insulation in old houses.
    Concrete doesn't corrode copper, but it might as well - the difference in expansion rates abrades the pipe. Eventually it will leak.
  11. hj
    concrete
    I cannot imagine ANY sane person direct burying ANY wiring under a concrete slab. Concrete does not "abrade" tubing passing through it because it is held rigidly and cannot move. Expansion/contraction WILL abrade tubing which has a rock pressed against it under the concrete, however. Trying to bend a short section of copper tubing will almost ALWAYS kink it.
Similar Threads: flexible pipe
Plumbing Forum, Professional & DIY Advice Old Flexible Lead Pipe, HOW to attach to? Mar 7, 2013
Plumbing Forum, Professional & DIY Advice flexible copper pipe question Sep 11, 2009
Plumbing Forum, Professional & DIY Advice Dishwasher Drainage Pipe To Flexible Hose Sep 11, 2009
Plumbing Forum, Professional & DIY Advice FLEXIBLE copper pipe? Nov 7, 2008
Plumbing Forum, Professional & DIY Advice flexible cpvc pipe ok to snake in walls? Sep 28, 2007
