frogdude13
What is the best legal flexible dishwasher drain option to install into a wall? This is for a multifamily building in Washington state. The objective is to find an easy way to get the waste to a sink drain on the other side of the kitchen. We're hoping to use something flexible since we need to get it through the wall studs that are already in place.
Here are a couple options that I've looked into and the issues that I believe exist with them. Maybe someone here can tell me why they will work or suggest a better alternative.
A) EPDM (rubber) hoses: These are sold for dishwasher discharge but I don't see this material listed as an acceptable drainage material under section 7. It's possible that I'm not looking in the right place though. If it's a questionable material then I am assuming the inspector wouldn't approve it.
B) Polyethylene: It appears to be an approved material.
- Black poly seems to be for cold only as best I can tell since there aren't any temperature ratings on product specs.
- Yellow poly looks like it would work based on product specs and availability EXCEPT for the yellow (gas) color.
How would you handle this?
