travelined
Hello,
I've had a Fleck 7000SXT is service for 5 years with no problem. This week, following the regen cycle, water was still flowing through the valve. After running through a number of manual tests stepping through the regen cycle, what is happening is the valve is not positioning correctly at each step. It keeps going past the correct position about 1/8 - 1/4" and stops between steps.
So, when it should be filling brine, it slips past that position and is essentially in "in service" position.
The motor appears to be working fine. I don't see any damage to the gears, etc.
With this valve using an optical positioning system, is there cleaning or adjustment to the cam position I can do, or should I be looking elsewhere?
Thanks so much for your help.
