Hi,
I used the hach-b test and we have 8-9 gpg depending not the day I test, but will set to 11gpg for occasions when hardness is higher. I just poured the gravel bed and 2.5cu ft of purolite C100E resin and our plumber connected to the house's softener loop. It's powered off until tomorrow.
We are a family of 5 with 3 pre-teens. My wife likes to take one to two hour long baths with the water running the entire time with the handles turned 50% open, drain open draining the water while refilling with hot water to keep the bath tub about 1/3rd to 1/2 full with constant water warm. She uses 200-400gallons of water each day depending on how long she is in the bath.
We have 1" PEX coming into house from our 5/8" x 3/4" municipal water meter.
1" PEX comes in/out of the softener and stays 1" as the trunk line for house and also runs directly to our 2 tankless rinnais in parallel with the rinnai ez-connect cable. The tankless use 3/4" pex and run directly to our master shower Brizo Thermostatic 3/4" supply valve with three 3/4" volume controls.
Fleck 5810XTR2 with 2.5cu ft resin
11gpg
municipal water, no iron
13x54 resin tank
18x40 brine tank
I would like to salt usage setting to be 10 lbs per cu ft.
We have red injector 0, BLFC = 0.125, and DLFC = 4gpm
I am going to set the system to backwash and unplug unit, then trickle fill the tank, then once water is coming out of drain line, will plug unit back in, set to rapid rinse and unplug, then open inlet 100% for 15 minutes, and then start a regeneration, and open the outlet to start up the system.
I do not know what settings I should use, can anyone please help?
Thank you!
John
11gpg
13x54 resin tank
18x40 brine tank
Thank you!
John
