Flange clearance, wax ring type, newbie questions w/ pics
Discussion in 'Toilet Forum discussions' started by Peterman, Apr 9, 2007.
  1. Peterman
    Peterman New Member
    Apr 9, 2007
    Hi all, my first post and I already have questions :eek: However, before I begin I'd just like to say... what an awesome site! If only I'd known about this site BEFORE my wife and I started a bathroom remodel...d'oh!
    Long story short, I recently remodeled my wife's bathroom which included installing a new tile floor. The tile was about 1/4" thick and installed on 1/4" cement backerboard. The previous floor was plain old linoleum. Due to the different flooring thicknesses, the existing closet flange would've been "recessed" about a half inch. Being the anal-homeowner type that I am, I decided to replace the closet flange rather than bridge that 1/2" gap. I cut the 3" ABS soil pipe and installed a new closet flange which mounted on top of the finished floor (see image below).
    [​IMG]
    The flange is perfectly level, and very secure.
    Question 1: Is this the *right* way to install the flange - I mean, on TOP of the finished floor? That's how it was on the old vinyl flooring, so in my case monkey-see-monkey-do. My father in law told me he's always seen the top of the flange "flush" with the floor...so I'm just asking.
    OK, second question on this topic. I'm now ready to put the old toilet back in, but I realized that the flange is about 1/2" thick, and there's barely 3/4" clearance on the toilet (see images below). This means that my compressed wax ring will be barely 1/4" thick at the thinest point, which makes me wonder if it will leak.
    Question 2: Is this kind of clearance normal? Is my closet flange too thick?
    [​IMG]
    [​IMG]
    Question 3: And my final question...I have both a traditional wax ring as well as the "reinforced wax ring and gasket" with the built-in rubber thing. Should I just stick with the traditional wax ring given my limited clearance?
    Thanks all!
    -Pete
  2. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    1. Perfect.
    2. Also perfect.
    3. Use the wax only.
    Nice work!
  4. Peterman
    Peterman New Member
    Apr 9, 2007
    ** breathes sigh of relief **
    Ah, this is good news! Thanks Ted! I just wanted to make sure I didn't screw anything up, looks like I'll install the throne tonight!
  5. jadnashua
    What you may want to do is set the toilet down as a trial without the wax ring and make sure it sits flat. If it rocks, mark where you need shims, and set them in place. Then remove the toilet, install the wax ring and then place it back down. Any rocking of the toilet after it is mounted will often overcompress the wax on one side and break the seal, so rocking is bad on a toilet.
Similar Threads: Flange clearance
Toilet Forum discussions Buying clearance with 14" unifit and offset flange Aug 8, 2016
Toilet Forum discussions Toilet Flange not Flat/Level Yesterday at 2:21 PM
Toilet Forum discussions Urine Smell and Rusted Flange Washer Monday at 12:45 PM
Toilet Forum discussions Sealing offset flange Feb 12, 2017
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
