fire sprinkler main and backflow devise.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by LBJAMES, Jun 21, 2011.
  1. LBJAMES
    LBJAMES New Member
    Dec 19, 2009
    LONG BEACH, CA
    I have a customer that needs a 3" water service for a fire sprinkler system with a backflow devise. not sure what backflow devise or type of pipe to use.
  2. hj
    They usually use a double check with rising stem gate valves. IT must be approved for that application by the proper testing bureau. The double check is installed ABOVE the ground at the required elevation, with the proper supports and bracing. Your fire department should have descriptions of the REQUIRED installation standards. BUT, why are YOU installing it? The fire sprinkler companies usually REQUIRE that they install it themselves, if for no other reasons than liability and performance.
Similar Threads: fire sprinkler
Plumbing Forum, Professional & DIY Advice Fire sprinkler alarm problem since water softener install Oct 8, 2016
Plumbing Forum, Professional & DIY Advice domestic PRV, check valves, and fire sprinkler question... Jun 23, 2016
Plumbing Forum, Professional & DIY Advice Fire Sprinklers attached Garage. Aug 2, 2015
Plumbing Forum, Professional & DIY Advice dripping in the fire sprinkler system Jun 16, 2013
Plumbing Forum, Professional & DIY Advice Water service upgrade for home fire sprinkler Apr 1, 2013
