Fiberglass Shower base has movement
Discussion in 'Shower & Bathtub Forum & Blog' started by Jim1327, Feb 28, 2008.
  1. Jim1327
    Jim1327 Tool and Diemaker
    Feb 24, 2008
    Tool and Diemaker
    installed a new fiberglass shower in our second floor master bath. I made sure the floor under the shower area was screwed down secure and had no movement. I installed the base as per instructions by placing 6 or 8 blobs of thinset morter and pushing the base down on the morter. I let it setup for 2 days and then finished the shower install. Everything was fine for about 6 months then I noticed the base would move a little when you stepped on it and got a little worse over the next few months. It has been over a year since I installed it and I still have movement. I am afraid this will eventually cause the development cracks or worse leaks in the base. I may be able to access it thru the back wall or making a hole in the cealing under it by the drain. Does anyone have any suggestions how to fix this problem? Thanks
  2. Nate R
    Nate R Member
    Jan 11, 2007
    I perform R&D testiing at small engine manuf.
    Milwaukee, WI
    Jim, we've already answered your questions. Why repost?
  4. Jim1327
    Feb 24, 2008
    Tool and Diemaker
    I wanted more replies. I like to get as much information from as many sources as possible. Before I make a decision on what to do.
    Jim
Similar Threads: Fiberglass Shower
Shower & Bathtub Forum & Blog Replacing a fiberglass shower pan, keeping wall tile - possible? Mar 6, 2015
Shower & Bathtub Forum & Blog Delta Shower Faucet in Fiberglass Shower; Hole Size? Remove Plaster Guard? Jan 31, 2015
Shower & Bathtub Forum & Blog Which Mortar for Bed for One-Piece Maax Fiberglass Shower? Jan 16, 2015
Shower & Bathtub Forum & Blog Replacing fiberglass tub/shower with shower Feb 9, 2014
Shower & Bathtub Forum & Blog Shower Pan (Fiberglass) Install on Wood Floor Sep 8, 2013
