fewest splices possible?
Discussion in 'Electrical Forum discussion & Blog' started by trackerxx, Mar 3, 2008.
  1. trackerxx
    trackerxx New Member
    Feb 27, 2008
    When running a dedicated 20-amp circuit for a gas dryer I assume you should run the wire with the fewest splices possible. What's the actual code for this? The wire run is about 40 feet and I am thinking I will need at least one junction box.
    Thoughts, opinions?
    Thanks.
  2. kd
    kd New Member
    Dec 11, 2006
    There is no limit on the number of splices. A properly done splice will have resistance equal to an unspliced piece of wire. Electricians try to limit splices because they take time.
  4. trackerxx
    Feb 27, 2008
    thanks
    Thanks.
    I appreciate it. I don't mind taking the time and am very methodical and careful to make good splices.
  5. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    You need a dedicated circuit for the laundry, but why do you feel you will need at least one splice?
  6. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    plug it into the same receptacle as the washing machine is plugged into
  7. trackerxx
    Feb 27, 2008
    splice
    I wanted a junction box to make the wire run easier since I am planning to do the run in sections. (Part of the run will be romex since it will be behind sheetrock.) The exposed parts will be EMT.
    I assume this is ok.
  8. kd
    kd New Member
    Dec 11, 2006
    Your splice should be mechanically and electrically secure prior to the application of the wire nut. Twist the bare wires.
  9. sbrn33
    sbrn33 Electrical Contractor
    Jul 9, 2007
    Fremont, NE
  10. jdoll42
    jdoll42 Computer Systems Engineer
    Apr 4, 2007
    In Illinois near St. Louis, MO
    I can't begin to tell you how many times I've seen wires fall out of the nut because they weren't twisted together first. I always twist my wires then nut them. Why risk a fire or something when you can just spend an extra 5 seconds twisting the wire together first?
    Also, at least for me, it's easier to get the nut on with the wires pre-twisted, especially when you are dealing with more than 2 wires. As ked said, just make sure they are mechanically secure before nutting them and you won't be sorry.
  11. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    It's because the nuts weren't twisted on tight enough, not because the wires weren't pre twisted.
    In a proper installation the wires will twist inside the nut. Personally I think it is harder with 4 to 5 wires to get a good pre twist going. The outside ones tend to slip around the inside ones. If they are all laid in and held together with your fingers, the nut will keep them from splaying apart.
    Is that a word?...splaying???
  12. jdoll42
    Apr 4, 2007
    The local inspector told me to not have more than 3 (maybe 4) wires under a single nut for that exact reason. I designed my wiring in my house to keep multiple wire junctions to a minimum. In some remodel work I've done with the inlaws, they had some nuts with 5 or 6 wires each under them. I broke that mess up into several nuts with only 3 wires each. I just feel safer that way. That's my $0.02 worth. Everybody has their own methods and reasons. That's just mine!
  13. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    You'll run into box-fill issues, if you take that logic too far.
    Also, more connections = more things that can go wrong.
    As for pre-twisting, it can cause its own set of problems, since it doesn't force you to twist the nut hard enough (that sounds wrong, lol...). So your connection might be solid, but the nut fall off - leaving you with an exposed splice.
    Nothing wrong with 5 or 6 wires under a single nut, but it's got to be the right-sized nut (i.e., NOT a red forced on & tape around the exposed bits of wire).
  14. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    I just installed a bunch of new Halo ICAT fixtures that came with push-in splices already attached to the fixture wires:
    (I'm not sure whose connector they used -- possibly OEMed.) Installing was a snap and very fast. I see a real problem if I ever need to change anything, but in this application it's not likely. Scuttlebutt from other forums is that they avoid the problems that gave backstab receptacles a bad name, and there's no twisting, etc.
  15. kd
    kd New Member
    Dec 11, 2006
    In my class we have experimented with pre twisting. If you do not twist, the connection is weak especially if you are doing more than two wires. One wire can slide out when you are shoving the wires into the box. Some manufacturers say "no need to twist wires prior to application of the wire nut" on the box--some do not. Are you going to stop and read every box? Also, who will be called back to fix a dead circuit? Conclusion: Refer to the King, Chubby Checker: Come on Baby, Let's do the twist!
Similar Threads: fewest splices
Electrical Forum discussion & Blog Correcting Exposed Direct Burial Splices Jun 1, 2016
