female pvc fittings
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by BluesMan, Nov 8, 2008.
  1. BluesMan
    BluesMan New Member
    Nov 8, 2008
    I just got a softener with the Clack-WS1 valve. The valve has 1" male threads coming out the back of the by-pass. i was planning on using pvc to pipe this in, but I know female pvc adapters are not allowed because they can crack. What can I use to connect up to these male threads? A brass coupling and male pvc adapter? I guess I could use a short peice of copper with a male and female adapter?
    Any better ideas?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    PVC should not be used for water lines inside the house. I would use copper.
  4. BluesMan
    BluesMan New Member
    Nov 8, 2008
    even if it's just cold water?
  5. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    What type of plumbing material do you prefer? CPVC, PEX, Copper ... that will dictate your fitting.
  6. BluesMan
    BluesMan New Member
    Nov 8, 2008
    I have PEX running throughout the home, but no PEX crimper. I was planning on 1" PVC for just ease of installation because the fittings are 1"
    It seems like copper is my next choice...i do have a "B" tank and turbo torch...so sweating is not an issue.
  7. 99k
    Aug 16, 2008
    If your have PEX in your house, then stay with PEX. You can either buy a crimp tool for less than $100 (then sell it on ****) or use Sharkbites (they are more expensive but don't require a tool). At the softener, use a Female thread x 1" adaptor.
  8. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    A contractor suggested that I use sharkbites to extend the water lines in my new kitchen sink base. This would have put them under the cabinet floor and therefore inaccessible. He says that he uses them even inside walls. Was that good advice?
  9. jadnashua
    They are code approved for hidden locations. A soldered connection is probably 20x cheaper.
  10. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Here we go again. Helmet on..........
  11. BluesMan
    BluesMan New Member
    Nov 8, 2008
    I am installing the softener in my parents home. There is a section of 1" copper from the meter and then switches over to PEX and up to the manifold. I guess I should just shell out the dough for the crimper and be done with it....
  12. burleymike
    burleymike New Member
    Nov 4, 2008
    Idaho
    You might be able to rent the crimper.
    The plumbing supply house in town used to loan you the crimper if you bought fittings from them. After people started using them as hammers and leaving them in the back of their trucks they stopped loaning them out.
    If I had a small job like that I would try to rent one before buying.
  13. Southern Man
    Jun 27, 2008
    North Carolina
    That's what I used. Of course though I used electrical solder just to get an asymmetrical reaction out some plumbers. :)
Similar Threads: female fittings
Plumbing Forum, Professional & DIY Advice PVC Male - Brass Female Coupling Oct 17, 2015
Plumbing Forum, Professional & DIY Advice Can Hose Bib (Brass Male) Be Connected Directly to Copper (Female) Not Fitting Smoothly Oct 14, 2014
Plumbing Forum, Professional & DIY Advice How to connect a female threaded shower valve Jul 9, 2011
Plumbing Forum, Professional & DIY Advice Is 1/2" female NPT the same as 1/2" FIP? Oct 9, 2009
Plumbing Forum, Professional & DIY Advice Are Female PVC Adapters/Couplings Junk? Jul 15, 2009
