Exterior repair/paint question on stucco
Discussion in 'Remodel Forum & Blog' started by Agu, May 21, 2009.
  1. Agu
    Agu New Member
    May 21, 2009
    Tampa, FL
    My house was built in the early 80's, concrete block with hand applied stucco over the block. We painted it about 5 years ago and the stucco was in perfect condition.
    About three years ago the house was hit by a mini tornado. I was home at the time and after it hit I went out front to see how big of a truck mistook my front yard for an interstate on ramp ;). No truck , but I lost about 30 barrel tile shingles and the joint tape connecting the ceiling and wall on that corner of the house was peeled away from the walls. Both an easy fix for a DIY guy since bids came in at $5 more than my deductible :(.
    However my house has since developed several hairline cracks in the stucco. I know that what I should do is become close friends with Mr Caulking gun and Mr Primer and then repaint the house. My concern is allowing moisture into the walls and developing even more problems, is that a valid concern? If so is there an easier way to seal the cracks prior to repainting ?
    tia
  2. manny1602
    manny1602 New Member
    Apr 15, 2008
    I would use Loxon from Sherwin-Williams and use a brush to fill the hairline cracks. Loxon stays flexible and with two coats applied perpendicular to the crack and feathered out at the edges hairline cracks are as good as invisible.
  4. dgold
    dgold Product R&D for a powertool manufacturer
    Dec 6, 2006
    Product R&D - Swimming Pool Industry
    Carlsbad, CA
    But DO get those cracks filled. They're like cancer on a stucco wall. Even if you have to use a bright white exterior caulk that stands out like a sore thumb in the interim, I'd do it.
    Don't use silicone caulk though -- it won't take paint.
    DAP has a good website, and on a few occasions I've submitted application questions to them and gotten very quick responses / good customer service in my limited experience.
  5. Agu
    Agu New Member
    May 21, 2009
    Tampa, FL
    Thanks for the heads up dgold, As much as I hate the option I think acrylic latex caulk followed with a good primer is the best option. I want to fill the cracks not just cover them.
    Tried the same formula of paint and after 6 years in the Florida sun there's no matching the color so I get to paint the whole house too :).
  6. dgold
    Dec 6, 2006
    Carlsbad, CA
    You might want to try a good paint store. Sometimes they can match if you can bring in a sample -- like a small piece of flaking stucco. Don't know what's down there, but I've had very good luck w/ Benjamin Moore dealers, and I've heard good things about the Sherwin Williams stores. The paint stores tend to cater to the pro's (vs. the boxes) and their customer service and desire to make you happy is worth the extra few bucks a gallon in my opinion.
    Two options as far as painting the whole wall.
    1. Being a landlord, I've learned to blend paint with a brush. paint the area that needs painting, but then use the brush almost dry to spread the wet area to the dry. If you get it right, and if the color is close it's hard to tell where the new begins and the old ends. Worth a shot.
    2. An extra coat of paint on the exterior isn't just for looks. It protects wood, stucco, & anything else from the elements. Probably the cheapest and easiest preventative maintenance you can do on a house. Besides, outside, (and I'm sure others will have dissenting opinions on this, but) there's plenty of places you can sort of slop it on and it never really looks bad.
Similar Threads: Exterior repair/paint
Remodel Forum & Blog What insulation for 2x4 exterior walls Oct 29, 2014
Remodel Forum & Blog DUROCK Cement Board for Exterior Walls Dec 25, 2013
Remodel Forum & Blog Exterior Wall Set directly on joists - is it ok? Nov 19, 2013
Remodel Forum & Blog Mold inside exterior walls, WTF!!! Feb 26, 2013
Remodel Forum & Blog Need some guidance on an exterior painting problem Sep 13, 2012
