exhaust duct
Discussion in 'HVAC Heating & Cooling' started by Eagle71, Aug 15, 2012.
  1. Eagle71
    Eagle71 New Member
    Aug 15, 2012
    Nj
    Hello all. Im finishing up a backsplash tile job and had to remove the stove vent duct. The plumbers came in to reroute heat pipes that now run behind the duct on the wall. The duct now touches the pipes a bit. I want to keep them seperate because of the possibility of corrosion between the copper and steel. I was thinking maybe plastic pipe straps on the copper pipe. Any recommendations? Also, i want to insulate a section of duct that runs through unheated attic space. Is the regular fiberglass duct insulation ok for stove exhaust ducts? Thanks
Similar Threads: exhaust duct
HVAC Heating & Cooling Can a bathroom vent exhaust duct be TOO short? Jan 30, 2017
HVAC Heating & Cooling Bath exhaust fan location advice Aug 23, 2016
HVAC Heating & Cooling AC vent and exhaust fan in same bathroom? Aug 12, 2016
HVAC Heating & Cooling Venting AV Exhaust Mar 25, 2015
HVAC Heating & Cooling Shared exhaust vents Apr 13, 2014
