Electrical Motor
Discussion in 'Electrical Forum discussion & Blog' started by Fishin, Jun 18, 2010.
  1. Fishin
    Fishin New Member
    Dec 21, 2009
    Virginia
    I have a 115V electric motor that runs a hydraulic cart. After 5 sec of running, it kicks the 20 amp breaker on the wall. It has two capacitors on the side, one start and one run? Would checking the capacitors be the first place to start? We direct wired the motor to an outlet but the results were the same. Thanks.
  2. jadnashua
    Look at the data plate for the motor and tell us what the model, voltage, and power numbers say. Did this ever work, or is it a recent problem?
  4. hj
    If you know how to test them and have the equipment, it would be the easiest place to start.
  5. Ford2001
    Ford2001 New Member
    Sep 11, 2009
    property care taker
    Manchester, Vermont
    The breaker may be the cause of your problem. Old breaker, don't handle the inrush current well, check to see if a HACR type should work. Read the motor name plate, and use the
    breaker they call for.
Similar Threads: Electrical Motor
Electrical Forum discussion & Blog Electrical supply to barn and garage Feb 9, 2017
Electrical Forum discussion & Blog Electrical panel- no ground Feb 1, 2017
Electrical Forum discussion & Blog Electrical wire accidently charred. Dec 31, 2016
Electrical Forum discussion & Blog Another long electrical run Nov 19, 2016
Electrical Forum discussion & Blog Quick electrical question Aug 31, 2016
