Electric Snake stuck in pipe
WackaWacka
Hello, I need some help. I've rented yesterday from HD a 75ft 1/2 in power snake. It feeds and retrieves the cable by itself, all I had to do is hold the guide pipe down. I struggled for a bit to insert the cable into the pipe through the clean out( located outside next to my kitchen pipe) because of a 90degree elbow that I could not bend the snake through. I took the arrow head off and succeeded to insert the cable with no head in the pipe. By my estimate I went 30-40 feet in. I retracted it and put a spring head on. Again could not get the cable past the elbow, so I took the spring head off. I managed to insert the cable again with no head in. I think I went about 40-50 feet and the cable went no more.I reversed and tried again with no success. I decided to retrieve it. No go! It's stuck in there. The machine has no power to pull it back. I tried reverse..... I tried forward and backwards..... I tried pulling it with my hands. Nothing! HELP!
I've read in some forum about powder soap to lubricate the pipe. True?
WackaWacka
I've posted a pic so you can see the machine and where I went in from
index.php
WV Bob
Huntington, WV
Got a come-along and a secure place to pull against?
Just the other day I read a post here mentioning running a snake through mud and maybe needing a truck to pull it back out once it's stuck. I hope it's not that bad in your case.
DonL
Houston, TX
I would hope it is out by now.
You need to be careful with what you put your snake in, and be able to pull it out quick.
Plumber69
Prince Rupert, British Columbia
This happend to me before, what I did was hook the end of the snake to a power drill and reversed it out, slowly lots of torque in the drill
