Electric Kickspace Heater Advice PLEASE
Discussion in 'HVAC Heating & Cooling' started by lori651, Oct 1, 2007.
  1. lori651
    lori651 New Member
    Oct 1, 2007
    Hi!
    We're in the midst of a kitchen remodel and are planning to install two electric kickspace heaters in the space. We're currently leaning toward Ouellet's OCP series and am admittedly picking them more for aesthetics than anything else.
    This is new territory for us DIYers and we are looking for any experienced advice on models, install watchouts, etc.
    Thanks in advance for your help! :)
    Lori
  2. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    like toasters, they are low-tech.
    The thermostat is the high tech part of the system. Spend a bit more to get "electronic" thermostats since they can do wonders to keep these heaters warm without blasting them ON and OFF the way old thermostats do. They also predict how much more heat you will need as the room gets colder after sundown and the thermostat senses that its trickle current isn't good enough anymore so it raises the current even before you can tell that the room temperature went down by a tenth of a degree.
    david
  4. lori651
    lori651 New Member
    Oct 1, 2007
    Thanks, David.
    We're definitely going with a good electronic thermostat. Any experience with, or knowledge of Oullet?
    We're feeling a little like we're throwing darts in the dark.
  5. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
Similar Threads: Electric Kickspace
HVAC Heating & Cooling Electric furnace element wont turn off Nov 30, 2015
HVAC Heating & Cooling Electric NG valve for outdoor kitchen Feb 28, 2015
HVAC Heating & Cooling Toe Kick Under Kitchen Counter Electric Heater Nov 1, 2014
HVAC Heating & Cooling Electric Baseboards or Central LP Furnace? Oct 20, 2014
HVAC Heating & Cooling Why AC air handler is Electric Furnice? Jul 29, 2014
