Ejector pump venting
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by catmandu, Dec 19, 2012.
  1. catmandu
    catmandu New Member
    Dec 19, 2012
    merlind
    Hello, I have found many answers over the years here, but now my search has come up a little empty, so I registered for my first post.
    Finishing the basement, which was roughed in for two full baths via ejector pump. The existing plumbing on the upper two floors uses a single 2" vent line, no other vent lines anywhere on the roof, so no dedicated vent put in for the ejector pit. The pit is not convenient to any chase or void to the roof without demolition, although it is adjacent to an exterior wall. The main 4" drain running horizontally across the ceiling of the basement (and then to the septic) has, near the end, one 2" clean-out in a relatively horizontal position which I assume is the place for the pit discharge, and then a 2" vertical line which I assume is vent.
    I have learned under no circumstance should the pit use an AAV, and rightfully it should have a dedicated roof vent. But, given what I have, what is the lesser of the two evils: using the 2" vent line (along with all the new basement drains) or running a 1" vent out the adjacent exterior wall (basically at street level)?
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
  4. catmandu
    catmandu New Member
    Dec 19, 2012
    merlind
    2006 National Standard Plumbing code, so not without some effort.
    Actually read the list of recent thread topics instead of searching, and found the one on this subject from two weeks ago where hj says he's done the tie in thing many a time. Don't particular care for the exterior pipe to the roof option (no offense, Terry).
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    If you think it would be OK to vent out the wall at street level, you might at well just go to the bathroom in the yard.
    I've put 1-1/2 and 2" drain and vent pipes vertically through the walls of stick-framed houses without any demo, and some without opening the wall up at all. It's just a matter of measuring and drilling in the right place.
    There are many easy ways to do something wrong, but only a few ways to do it right.
Similar Threads: Ejector pump
Plumbing Forum, Professional & DIY Advice Sewage ejector pump Nov 5, 2016
Plumbing Forum, Professional & DIY Advice Sewage Ejector Pump Question Oct 28, 2016
Plumbing Forum, Professional & DIY Advice Ejector pump check valve making 3 knocks when closing Jul 11, 2016
Plumbing Forum, Professional & DIY Advice Ejector pump siphoning traps on 2nd floor Feb 8, 2016
Plumbing Forum, Professional & DIY Advice Septic tank/sewage ejector pumps Dec 21, 2015
