efficiency of +20 year old Weil-Mclain oil boiler P366(HE)?
Discussion in 'Boiler Forum' started by hillpc, Sep 23, 2009.
  1. hillpc
    hillpc New Member
    Sep 23, 2009
    Pennsylvania
    The boiler with Beckett AF burner was here when I moved in. I assume
    the HE stands for high efficiency, but what was that 20 years ago? I
    could keep this boiler going for a long time, but wanted to check if
    it's worth it to replace with new. The Weil-McLain website has a
    calculator but doesn't have the info I need. It shows a 78% default
    efficiency; going from this to 86% or so saves me a little over $200/
    year (at $2.40/gallon). Seems like that'll take quite a while to
    recoup at a boiler equipment only cost of over 2 grand.
  2. flamefix
    flamefix New Member
    Sep 4, 2009
    Heating engineer in the UK licensed to fit service
    Exeter, England
    A flue gas analyser with the oil flow rates set should give you some idea of the efficiency. A modern condensing oil boiler will give you 95-7% efficiency.
Similar Threads: efficiency Weil-Mclain
Boiler Forum Westinghouse 80k BTUh boiler setup for best efficiency Nov 19, 2016
Boiler Forum Efficiency of Modulating Boilers Mar 23, 2013
Boiler Forum Disappointing efficiency of alpine condensing boiler? Feb 5, 2013
Boiler Forum Boiler Size vs. Efficiency Jan 23, 2013
Boiler Forum pH neutralizing media on high efficiency boiler Aug 25, 2012
