DVW, Cleanouts, in detail--Cleanout specs
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by civ2100, Dec 8, 2007.
  1. civ2100
    civ2100 New Member
    Dec 8, 2007
    I am redoing a bath over a 3 ft. crawl space, to make handicap shower, with full-floor shower pan. Wanted to extend old cleanout at bottom of toilet-stack/vent. Asked plumber via a scaled drawing to slope up drain extension at 22-1/2 degree angle starting at "dirt" level, picking up the new shower drain and vent connections on the way, going through my last reinforced joist at the outside wall, and adding the cleanout in outside wall just above foundation. My design for the main line extension had a 45-degree total changes in direction. Instead he used 2 90-degree bends just inside foundation, to go up from gently sloped 3-inch line about 12 inches up from the dirt, and then out for the cleanout. These 90-degree (or quarter-bends) are not tightest radius, but neither are they long-sweep.
    Does his solution pass code in California? Do plumbers treat customer sketches or drawings this casually often, or is this an exception?
  2. hj
    co
    Does his solution pass code in California?His solution, even if it did pass code, would be more difficult to use than two 45's would have been.
    Yes, but I also do it with engineer's drawings so don't assume your's is a special case.
  4. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    If a customer tried to tell me how to plumb, I'd wad up his drawing and toss it at him, then tell him to do it himself. I've earned my spurs. I'll use 'em.
  5. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    I'm a Ca. Gen. C. that does a lot of plumbing. I see nothing wrong with Your request. Sounds like You gave this some thought. I wouldn't break the code for You. But I find no problem with what You wanted. At a minimum, He should have discussed any different ideas ,with You first! Just good manners,and Business.
Similar Threads: Cleanouts detail--Cleanout
Plumbing Forum, Professional & DIY Advice Toilets, horizontal wet vents, and end of line cleanouts Jan 2, 2015
Plumbing Forum, Professional & DIY Advice 2012 UPC + Cleanouts Mar 5, 2014
Plumbing Forum, Professional & DIY Advice Pressure Testing & Cleanouts Nov 26, 2012
Plumbing Forum, Professional & DIY Advice Are there Eschucheons for cleanouts? Jul 9, 2011
Plumbing Forum, Professional & DIY Advice Cleanouts/Test Tees Jun 14, 2011
