Duel shower heads
pwgsx
Tx
I just ripped out my bathtub and am making the area into a shower. Since the area is so long for a shower, I was thinking of putting shower heads on both wallls, only issue is the main big wall is a outside wall and im worried about freezing a pipe. Im in Tx., so it doesnt get that cold but we do get some low 20's and teens in Jan. and Feb. The main water supply comes from a inside wall thru the floor. How would you rout the Hot and Cold to the other side??
First I though cut a notch thru the back wall studs and wrap the copper pipes with that pipe foam stuff. I also thought of going up in the ceiling and down but the attic. I also had a passing idea to run the 2 pipes in between the curb I have to make for the shower since that area wouldnt get cold. Any thoughts?? I doubt if any would be up to code but im looking for functionality. lol
Basement_Lurker
One who lurks
Victoria, BC
What's in that bulkhead above the shower...a furnace run? So long as you keep the valve and pressurized piping where they are, I think you will be fine so long as you pipe things properly and keep the runs behind insulation. If you are really paranoid, you could install a toe tester which would allow the showerhead lines to drain after use...so long as you sloped the piping properly.
