Dual Water Pumps / Boats
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by lawrencetj, Apr 4, 2008.
  1. lawrencetj
    lawrencetj New Member
    Apr 4, 2008
    Greetings Everyone,
    I have a unique setup I haven't seen on here yet. I've even tried a few of the ideas to see if these resolve my problems. But alas, it's still a no go.
    Here's my problem.
    I work on a boat that has two water pumps. One of the pumps works fine now that I've replaced the pressure switch. The other pump still acts up. WHenever there is a drain on the water system (shower, toilet, sink, etc.) the pump pressure drops suddenly and charges back up just to drop suddenly until the other pump kicks on and puts everything right again.
    Here's my setup.
    I have two water tanks. Each tank connected to the other through an equalizing pipe. Off this pipe, two pipes provide the supply for the each pump. On the supply line, there is a gate valve and then a check valve. Coming off the pump, I have a T fitting. One way is a large plastic hose (1 in or 1 1/2) that feeds to the pressure tank and the other leads to a check vavle and then the rest of the boat.
    What I've done so far...
    The other day, a coworker added air to the tank and it stopped the behavior for two days. But it's back and just as bad. 40 PSI is high, down to 20, then back 40. Repeat till the other pump puts up 40 PSI. I've replaced the check valve off the water tank side. I checked the tank for air leaks but can detect none. Not even off the air nozzle. I don't have an air pressure gauge, so I can't tell how much air is in there now.
    Does someone have an idea on where to proceed with this? Any help would be greatly appreciated.
    Thanks,
    Timothy
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    It sounds like you just have the check valve in the wrong place. It should be pump, check valve, then tee to pressure tank and usage line.
  4. lawrencetj
    Apr 4, 2008
    That's the way it's always been. It's still got the 20 layers of paint over it. :D
    But seriously, that's the way it's been designed and implemented on all our boats . Was working before.
    Thanks,
    Timothy
Similar Threads: Dual Water
Pumps and Tanks Well Forum & Blog. Water is life. Dual CSV Jul 31, 2016
Pumps and Tanks Well Forum & Blog. Water is life. can I use a 3/4 hp dual cap control box on my 1/2 hp Goulds 10GS05 pump Mar 7, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Anyone using dual sump pumps? Aug 26, 2008
Pumps and Tanks Well Forum & Blog. Water is life. Dual Check Valve Question Feb 14, 2007
Pumps and Tanks Well Forum & Blog. Water is life. Can/Should I install water meter in Single Family well fed system? Tuesday at 7:43 AM
