Drop in tub help needed
NJPA
Hello Everyone !
This is my first time here on the site. I need a little help.
I am installing a drop in Jacuzzi brand tub. The instruction don't say any more than to set in mortor or expansion foam. My floor was not level so I put down some thin set. I built out my box/tub surround in an alcove. It's all level. So I was told I shold take Structolite and make a nice mound of it and mush the tub down into it until it stops on my tile, fill the top half way and leave it until it drys. Correct ? Anything else I should do ?
Thank you
Krow
Ontario, Canada
Just make sure it is level
and you have a good helper with a least a half a brain to help you set it in place lol :D
A bad helper can really screw things up for you
NJPA
Hey Krow,
Thanks for the reply.
Is it ok that my box/surround(sorry -- dont know the actual name for it) is level ? It should matter about the floor right, since the structolite will be supporting the tub?
tub
How else would you make it? If it is not level the tub will not be either. Put a sheet of plastic over the Structolite or whatever you use so the tub does not get cemented into place. Do NOT tile up to the tub. Either tile first and then install the tub on top of the tile, or set the tub and then tile over, not against, the rim of the tub.
NJPA
What I meant was, my floor is not level, but I made my tub surround framing level. So as long as I go into the structrolite and mush it down to the tile, and stop --- I should be good correct ? Since my framing is level.
Thanks
Krow
Ontario, Canada
Thanks
That will be fine. By making the frame level, the tub will automatically become level. Its horrible trying to level a teb with a out of level frame lol ;)
inexplorata
Colorado
Wrap that sucker with as much insulation as you can. I just put one in and left one side uninsulated so I could check for leaks after a few baths... you could really tell which side it was.
NJPA
I've never done one before Krow. So I really wasn't sure how to go about it. But just glad that's the way and it would work. I figured it should lol
Inexplorata --- I heard that you have to watch with the insulation because it over heats the motor ?? Ever hear that ?
Is it really loud?
Thanks
NJPA
Wrap the tub itself with insulation? or fill the surround walls with insulation?
Thanks !!
