Driven well chlorination
Discussion in 'Pumps and Tanks Well Forum & Blog' started by twist, Nov 27, 2012.
  1. twist
    twist New Member
    Nov 27, 2012
    Quebec
    Hi all,
    This is a basic question that was probably already posted (or not because not found), but here I go.
    I have a 2" driven well, PVC pipes, around 20 feet deep. I want to pour down chlorine to do a shock chlorination. But I seem to be missing something here. The pipe heads out about 1 feet overground. So I remove the cap and pour down the chlorine solution. The problem is that it fills up with less than a few cup and does not seem to go down. I guess I have a pitless adapter and it does not get pass through it and there is nothing I can do there. After many hours the chlorine will have gone "somewhere" but it never smells chlorine at the faucets. I'm even beginning to think that I am doing more harm than good with the chlorine mixture sitting there for all those hours.
    By principle, when I do not find a solution on the Internet then I should not be having a problem because it does not exist.... So can somebody point me out in the right direction.
    Thanks.
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    A driven well does not use a pitless. A pitless does not act like a checkvalve.
    Something else is at play. Perhaps a checkvalve was put inline just above the sandpoint.
  4. twist
    twist New Member
    Nov 27, 2012
    Quebec
    Unless I am mistaken (which would explain something) and considering the information I've got from the installer, my installation would look pretty much like page 7 of this document (http://dnr.wi.gov/topic/DrinkingWater/documents/pubs/DrivenPointWells.pdf).
    There would be a pitless adapter, at least six feet down (below frost level) between the screen pipe and the pipe that goes in the house. The check valve is just between the pump and the pipe in the house (this I can confirm). I do not see why there would be another chech valve at the junction of the two pipes. I am not able to look down the pvc pipe to confirm the type of adapter...
  5. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    There has to be a check valve betweem the pitless adapter and the well point otherwise the chlorine would go down!
  6. twist
    twist New Member
    Nov 27, 2012
    Quebec
    If it is the case, does not seem a good idea since I already have a check valve at the pump. Also, the chlorine manage to get pass (where?), but after many hours (I did not check exactly how many but less than a day...) which I find strange. Not practical and I wonder if such long contact with the pipes (PVC) and adapter can harm.
    I guess I will try to locate the person who drove and installed the pipes and get in touch with him.
Similar Threads: Driven chlorination
Pumps and Tanks Well Forum & Blog Problem with a driven well Aug 17, 2016
Pumps and Tanks Well Forum & Blog new driven well Sep 4, 2015
Pumps and Tanks Well Forum & Blog iron build up in a point driven well Jun 16, 2015
Pumps and Tanks Well Forum & Blog water table info for a shallow sandpoint driven well Oct 2, 2014
Pumps and Tanks Well Forum & Blog Sand in my driven point well Dec 20, 2013
