Drain size for washer in Canada
Discussion in 'Canadian Plumbing Code Questions' started by MIKE007, Aug 26, 2013.
  1. MIKE007
    MIKE007 New Member
    Aug 24, 2013
    Montreal
    My vertical drain is 1 1/2. There is a dishwasher + kitchen sink on the first floor and a washing machine in the basement connected trough a back flow valve after the p-trap. I newer used both washing machines at the same time. Is this diameter fine for both machines at the same time or I need 2"?
    Thanks
  2. dj2
    dj2 Well-Known Member
    Aug 13, 2013
    California
    You need 2". Why is your drain 1-1/2"?
  4. mikeplummer
    mikeplummer Plumber
    Mar 28, 2012
    Ontario, Canada
    maximum hydraulic load (fixture units) drained to a 1-1/2" soil or waste stack - 8FU
    maximum fixtures units from any one storey drained to a 1-1/2" soil or waste stack - 5FU
    kitchen sink = 1.5 FU
    dishwasher = if separately trapped with 1-1/2" trap - 1FU if connected to sink or garbage disposal - 0FU
    clothes washer = 1.5FU with 1-1/2" trap
    assuming all piping and venting is proper - your arrangement meets code requirements
  5. MIKE007
    MIKE007 New Member
    Aug 24, 2013
    Montreal
    Thank you for your answer.
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I believe Canadian codes are different in that they have not upped the drain sizes as the US has. Your 1-1/2" may be legal, but 2" sure would be better.
  7. Bill Shack
    Bill Shack 30years plumbing 10years plumbing inspector
    Mar 10, 2014
    retired
    montreal quebec Canada
    I disagree, The pipe must be at least 2 inches, Further the Quebec amended canadian code is about to change so that all laundry machines connection are minimum 2 inches.
  8. mikeplummer
    mikeplummer Plumber
    Mar 28, 2012
    Ontario, Canada
    the Ontario Plumbing Code is also changing the minimum drain size for a laundry pipe to 2"
  9. Toto
    Toto New Member
    Apr 3, 2015
    Nova Scotia
    Does this plumbing code differentiate between the different types and sizes of washers? I am asking, because I am trying to get a plumber install a compact, 2.2 cu ft., 24'' wide, front load washer in the place of my dishwasher in my kitchen. And despite the fact that the washer's manual asks for a minimum of 1 1/4 '' drain pipe, all I get by the plumbers is that can not do the job because my drain pipes are 1 3/4'' whereas their codes requires dain pipes for washers to be 2''.
    I am not a professional plumber, but I think there is quite a difference between a 6 cu. ft . washer and a 2.2 cu. ft. washer. So do these plumber codes make a difference based on the size of the washers and the amounts of water they use in setting the drain pipe requirements?
    Actually, I would appreciate your opinion regarding my project. You can see the details in the add that I have posted in an effort to find a plumber do the job:
    http://www.kijiji.ca/v-plumber/city...er/1061687666?enableSearchNavigationFlag=true
Similar Threads: Drain size
Canadian Plumbing Code Questions Minimum drain pipe size for a lav Mar 31, 2013
Canadian Plumbing Code Questions I need to know the vent size for a 2 inch shower pipe drain Oct 7, 2010
Canadian Plumbing Code Questions Washer Standpipe and Laundry Sink Drainage Reconfiguration Jan 14, 2017
Canadian Plumbing Code Questions Washing Machine with Utility Sink - 1-1/2" Drain! Dec 6, 2016
Canadian Plumbing Code Questions Want to tie into washing machine drain Mar 7, 2016
