Drain size for tub/shower combination
Discussion in 'Shower & Bathtub Forum & Blog' started by Home Girl, Nov 23, 2009.
  1. Home Girl
    Home Girl New Member
    Nov 11, 2009
    Vacaville, CA
    I am reading that the tub drain should be 1 1/2" while a shower drain should be 2". If a tub/shower combo is installed, can a standard tub drain be used, or does that require a larger shower drain?
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    What do you mean by tub/shower combo? Tub with a shower head? If so the 1-1/2" drain will work. The idea is that the tub can provide holding space for water if the drain is slow, a shower doesn't offer much if any holding before you overflow the curb.
  4. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    The smaller size drain works.
    It also works for showers too, and that used to be the size required by "Code" too. I think that bigger houses and longer distances are the reasons why its size was increased to 2".
  5. Inspektor Ludwig
    Inspektor Ludwig Journeyman/Inspector
    May 11, 2006
    In the good ol' UPC
    Yes, you can have an 1 1/2 drain for tub/shower combo.
  6. hj
    1 1/2"
    You are too young to remember when a shower was permitted to have a 1 1/2" drain. I am also.
  7. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Florida used to require all under slab plumbing to be minimum 2". Now they don't, along with allowing CVPC (with joints) underslab....
  8. plumbergreg
    plumbergreg New Member
    Jun 26, 2009
    Ontario, Canada
    The sizes in the code are the minimum size not the required size;)
Similar Threads: Drain size
Shower & Bathtub Forum & Blog Shower drain size going from tub to shower Feb 25, 2017
Shower & Bathtub Forum & Blog Need help with a drain size Jun 20, 2016
Shower & Bathtub Forum & Blog Question on trip lever tub drain-bucket size universal? Aug 31, 2014
Shower & Bathtub Forum & Blog Shower Drain Size and Code Feb 17, 2012
Shower & Bathtub Forum & Blog drain and overflow hole size and compatability of tub waste /drain Aug 6, 2011
