Down Well Pressure Tanks?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by dsk, Apr 1, 2006.
  1. dsk
    dsk New Member
    Feb 24, 2006
    Someone I know told me that it's possible to buy pressure tanks designed to fit down into the well casing. Sounds suspicious to me, and I can't google anything that looks like what my friend describes. So how about it? Does such a beasty exist?
    If so it would be a neat way to get rid of the pump house that I'd otherwise have to build.
    DSK
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Your friend is correct. However they haven't been around for a long time and they depend on a CSV valve or Smart Tee to make them work. I would just go with the CSV valve and a small bladder tank. Then if it goes bad, you won't have to pull the pump to replace it.
    bob...
  4. Hube
    Hube New Member
    Sep 1, 2004
    Ontario
    since there are many, many well casings that are in the 4" to 6" diameter(deep well/ sub pump), it would be very interesting to see a picture of one that will actually fit into this size of casing. :)
  5. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
Similar Threads: Down Pressure
Pumps and Tanks Well Forum & Blog. Water is life. Shared well, water pressure jumps up and down May 15, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure slows down. Aug 2, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Strange well/pressure tank problem . . . Missing Drawdown! Jun 18, 2011
Pumps and Tanks Well Forum & Blog. Water is life. pressure in well leaking down after pump shuts off Mar 6, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Should downhill distance be considered for head pressure of sump pump discharge ? Aug 3, 2010
