Double Throw Pressure Controller Switch
Discussion in 'Pumps and Tanks Well Forum & Blog' started by SnittyKitty, Mar 15, 2009.
  1. SnittyKitty
    SnittyKitty New Member
    Sep 4, 2008
    Is there such a thing as a pressure controller switch that can be grid-tied and generator tied without rewiring the darn thing? It has to be a switch that doesn't put generator power back on the grid something that you see in automatic transfer switches and double pole. I'm leaning on the idea of buying a 4 prong 220 VAC male plug that inserts into my generator and running 250 VAC rated outdoor wire within electric conduit directly to the pressure switch but the question is how once I'm there with the wire; thanks.
  2. Gary Slusser
    Retired
    I've never heard of anything like that but I'm sure it could be done with the right electronic controller(s). Me, I'd flipe the breakers on the pump and plug in the generator plug after doing that and starting the generator. I might rig up a plug on the line from the breakers to the switch so it didn't backfeed to the panel box. But then this is all without thinking this through fully.
  4. thassler
    thassler Member
    Dec 5, 2006
    Systems Analyst
    Tennessee
    I've used these before:
    http://www.nooutage.com/CSR.HTM
    There are several different models to choose from, depending upon if indoor/outdoor is needed. They can be installed on the load side of a branch circuit breaker. I installed one at my pump house so during a power outage I could start the generator, flip the transfer switch and have water with no danger of the generator backfeeding the grid.
Similar Threads: Double Throw
Pumps and Tanks Well Forum & Blog Shallow well problems - sorry about double post. Oct 13, 2015
Pumps and Tanks Well Forum & Blog Jet pump pressure switch double picking Aug 12, 2014
Pumps and Tanks Well Forum & Blog Square D double click at shut off Aug 12, 2012
Pumps and Tanks Well Forum & Blog WTB: vertical float with about 10" travel OR double float Apr 24, 2009
Pumps and Tanks Well Forum & Blog double tanks + check valve Aug 5, 2008
