Dole Valve vs. Gate Valve
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by turkeyvulture, Apr 9, 2013.
  1. turkeyvulture
    turkeyvulture New Member
    Feb 5, 2009
    California
    I am dealing with a low-yield well and storage tank situation. Dole valves keep coming up in the discussion. Can anyone say why a Dole valve is better than a gate valve? Seems like with a gate valve, you can adjust it to just below the well's yield. With the Dole valve, you have to know what the yield is, which may vary seasonally, and if you put in the wrong one you get to buy and put in a different one.
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    They both accomplish the same thing. The gate valve will rattle loose and/or wear out, and the flow rate will increase without you knowing it. The Dole valve is designed to last with less than 125 PSI differential pressure. We usually use a Ball Valve as it doesn’t rattle loose. Take the handle off so nobody messes with it. But even a Ball valve will wash out with the water jetting through. So after testing the flow rate with the ball valve, you can replace it with a Dole valve of the right flow rate.
    Do you really need a restrictor of any kind? If the pump will run at least 5 minutes before pumping the well dry, I would just use a Dry Well protection relay like the Cycle Sensor, and figure out how long to set the time to restart after pumping dry. The pump will produce more gallons per KW of electricity this way, as long as it doesn’t cycle more than say 30 times per day.
    Either way you don’t have to restrict it to the exact recovery rate of the well. Just restrict the flow rate so the pump runs for 10 minutes or more before being shut off by the Dry Run relay. If the well will recover in 30 minutes, that is a cycle every 40 minutes, or 36 cycles per day. Just restrict the flow to make the pump run the length of time you want.
    A short ¼” nipple makes a good restrictor as well, and a Stainless Steel nipple will last a long time.
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    +1 on the ballvalve. Gate valves are so former century and are hard to do minor adjustments on.
  5. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    Hate gate valves, especially old ones when the stem breaks and the gate drops.....
  6. lzenglish
    lzenglish New Member
    Aug 4, 2009
    Retired
    CA
    I have ALWAYS used a "Globe Valve" for flow control, as that is what it is designed for! Never on a residential well pump system, but many many times on Commercial Applications.
    Any Thoughts?
    Wayne
Similar Threads: Dole Valve
Pumps and Tanks Well Forum & Blog. Water is life. Dole Valves May 19, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Dole flow control valves Feb 4, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Do you pump into a cistern with a dole valve or just let it flow? Feb 14, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Solenoid valve and Float switch Voltage, wiring? Tuesday at 2:45 PM
Pumps and Tanks Well Forum & Blog. Water is life. Well head pressure relief valve Feb 6, 2017
