Does anode work if broken from tank top?
Discussion in 'Water Heater Forum, Tanks' started by CHRPC78, Feb 26, 2010.
  1. CHRPC78
    CHRPC78 New Member
    Feb 25, 2010
    When I cleaned lime/calcium from bottom of 58 gal tank, I saw a long section of anode laying at a 45 degree angle crossways on the tank bottom with a very small "ferrous" wire still attached that was vertical up toward the top of the tank. I assume that the anode is still "grounded" to the tank body but I am not sure.
    In any case, does anyone know if the anode will still work if it is not attached, that is if it is broken off and fully disconnected from the tank wall?? Do I need to try to retreive broken anode? Is there any other problem with this situation?
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    No it needs to be connected to the tank. The protection the anode affords is electrical in nature and the anode must be electrically connected to the tank itself.
Similar Threads: Does anode
Water Heater Forum, Tanks Does anyone change anode rods? Nov 27, 2010
Water Heater Forum, Tanks Heater does not kick in after replacing heat exchanger Aug 29, 2016
Water Heater Forum, Tanks Does anyone sell an anti-stacking pump? Aug 22, 2015
Water Heater Forum, Tanks Does the drain fitting unscrew from water heater body? Jul 7, 2015
Water Heater Forum, Tanks When does a hot water decide to heat water Apr 1, 2015
