Driver
Hi.Sound stupid, but here my question.
I recently removed my vinyl/underlayment(3/8") to get ready to install a ceramic tile flooring. I notice that after taken the wax off, the item I see is a cast iron looking flange or ring of a drain pipe(not sure). It have two v shape cut out where I assume the flange bolts were attached to(the bolt rusted out and remain attached to the toilet itself. (the head is completely gone). This means the stool were never attach to the floor all this time and without any movement.Now this flange or drain ring have no screws of any kind attached to the subfloor. The way the sub floor opening were cut, it seem like its siting on edge of the cut out but never attached to the subfloor. So I assumes tht this flange or drain ring is only just attach with lead to the cast iron and hanging on edge of cut out, correct?
Now the question is, do I buy a closet extenion and just set above It. I will bolt right into the floor and directly over the old flange? Will this create a gap which will cause a possible leak between the extention and the existing flange or drain ring? Still not sure if it a flange or just a drain opening?
I'm confuse.
I'm confuse.
