Yar02169
Hello-
I use my well and pump just for irrigating my lawn and upsetting my neighbors with a green lawn. I've detected a leak near my pressure gauge, so my plan is to rebuild that part of the system. I'm wondering if I need the pressure tank. The current tank is a baby, maybe 4 gallon or so. I have yet to get the system working on the automatic timer, and I would like to blame the tank for not being adjusted properly. I'm trying to figure out why I have a tan in the first place. When a solenoid opens, pressure drops, pressure switch turn on pump. When time is up, solenoid stops flow, pressure raises and switch shuts off pump.
Does the tank act as a surge protector when the solenoid closes, acting like a safety cushion for the pvc piping? When I water, the pump will cover 5 zones, each zone running for at least a half hour. With no short term water usage, do I really need the tank? I'll trust you guys, so if you say I need it, I'll rebuild and use it, even if I think the tank is ugly and not needed.
