divertor valve
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jake_lamada, Jan 29, 2007.
  1. jake_lamada
    jake_lamada New Member
    Jan 28, 2007
    analyst
    canada
    I recently installed divertor valves in both bathrooms due to leaking. The leaking problem is no solved but when you pull out the handle to divert the water to the showerhead it bangs really hard. If you are downstairs it sounds like the bathroom is coming through the floor. Anybody having same problem or know the cause.
  2. hj
    diverters
    What kind of pipe did you use?
  4. jake_lamada
    Jan 28, 2007
    analyst
    canada
    Hi,
    Copper piping as far as i know..
  5. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    Sounds like you did not anchor the shower head pipe solidly enough...
    Try to turn the shower diverter on while holding the shower head - If you feel a hamer, that is probably the problem...
Similar Threads: divertor valve
Plumbing Forum, Professional & DIY Advice shower divertor valve Aug 7, 2009
Plumbing Forum, Professional & DIY Advice ProPEX shower valve instalation Today at 10:13 AM
Plumbing Forum, Professional & DIY Advice Pressure reducing valve is leaking... can i maybe just remove it? Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Help with replacing shut-off valve Feb 12, 2017
Plumbing Forum, Professional & DIY Advice New shower / check valve question Feb 9, 2017
