Dishwasher with no Garbage Disposal
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by micalk, Apr 14, 2007.
  1. micalk
    micalk New Member
    Aug 28, 2005
    Electronics Engr
    Simi Valley, CA
    How's it done? The instructions have the dw drain going straight into the plumbing, no air gap. Can it be run similar to a clothes washer drain, where the output of the dw is hooked over the edge of a drain pipe angled out of the wall with a P-trap at the bottom? What are my options? This is a Fischer-Paykel single drawer and will be used mainly for cups and silverware at the coffee bar, so I'm not concerned about any heavy waste, though my main dw is a little far from the kitchen sink, and may employ a similar technique there, if practical.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Air gaps are not always required by local codes. If one is not used, then the drain hose must be looped and attached under the counter top. It attaches to the sink drain with a special tail piece that has a pipe stub teed out of it that the hose clamps onto. If an air gap is required or desired, then it is install in the counter top. The hose attaches to the drain the same as described above.
  4. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    Dishwasher Branch Tailpiece. Search for that. Add "tubular" as one more keyword if necessary.
  5. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
    Dishwasher tailpiece
    As Gary said, an airgap may not be required. Check with the local plumbing authority in your jurisdiction. If you don't use one, just be sure to loop the drain hose and attach it to the underside of the counter.
    Good luck
  6. micalk
    micalk New Member
    Aug 28, 2005
    Electronics Engr
    Simi Valley, CA
    Thanks, RioHyde - That's exactly what I was looking for. AFAIK, I'll need an airgap too, but that's between me and my inspector....
Similar Threads: Dishwasher Garbage
Plumbing Forum, Professional & DIY Advice Air Gap pumping water outside, Dishwasher, Air Gap and Garbage Dispenser all are new Oct 4, 2015
Plumbing Forum, Professional & DIY Advice Kitchen sink/dishwasher/garbage disposal drain size question Jul 25, 2015
Plumbing Forum, Professional & DIY Advice Double Sink double dishwasher garbage disposal dilemma Jan 11, 2012
Plumbing Forum, Professional & DIY Advice Garbage disposal install in double sink w/dishwasher... why do I have two drain pipes Dec 7, 2011
Plumbing Forum, Professional & DIY Advice Dishwasher & garbage disposal - for septic field drains Feb 12, 2011
