Dishwasher Drain in island without sink
CorCon
Rochester,NY
Hello. Newbie here…
I’m converting a carriage house to a 2 BR, 2 bath apartment and they asked I look at the main house to assess some plumbing issues. The plumbing here is atrocious as it was a 2 family rental converted back to a single family. The DW hasn’t been used in some time because it wasn’t draining and the kitchen sink on a half wall was gurgling during use. Upon inspection, found a P trap under the sink with disposer with the DW drain hose tied in. 1 1/2” PVC was then trapped again in the basement. DW discharge is routed through the floor, extended, then back into sink base for tie in.
My plan is to remove the dishwasher drain from disposer and plug the inlet. Convert S trap to P trap with proper extension arm and add an AAV.
In the island, I have to remove pull out drawers from the cabinet adjacent to the DW to stub 1 1/2” in. Adding a sani tee at 10”+ AFF with trap and 18” standpipe, venting with aav around +/-33” to top of valve.
The question becomes…direct fitting to top of standpipe after high loop OR INDIRECT with high loop fastened and dumping in to standpipe similar to washing machine. High loop would be ~2” higher than standpipe termination. I’ve read through the forums and can’t find a suitable answer for this application without an air gap (not an option on a 26”x 50” island), Johnson tee isn’t an option, and vented loop isn’t the issue as it’ll have AAV.
Direct barbed fitting to trapped standpipe or indirect? The other thought was DW branched tailpiece on standpipe with tailpiece open at top below high loop, similar to the wye fitting on standpipe mentioned in some posts
John Gayewski
Iowa
A pvc air gap fitting won't work? If not you could get a backflow air gap and rig something up.
John Gayewski
Iowa
